I have a laptop with a rtx 2070 max q. I have changed the thermal paste to thermal grizzly carbonaut so I won't have to change the paste everytime I open the laptop, So i have used kapton tape to isolate the pins located on the die to prevent shorting out the gpu.
The laptop turns on, everything works, no artifacts, no bsod but I have noticed that my gpu power package went from 90W to 65W in performance mode and it stays there. So I am trying to understand what went wrong, any help will be appreciated.
P.S. should I change it back to a normal paste?
https://linustechtips.com/topic/1245247-gpu-low-power-package/
14 minutes ago, Charlie Groves said:
You sure it is being cooled correctly? check temps
With aida64 stressing only the gpu, temps are around 73-74c max. I am clueless. I have also noticed the power is at 90W for 5 sec and then goes slowly to 65w. Maybe the vrms are overhearing?
https://linustechtips.com/topic/1245247-gpu-low-power-package/#findComment-14008729
