So I have an MSI Z370 Gaming Plus Motherboard, which has no Bluetooth on board. However it has the following extension PCIx Ports: (1 x PCIe 3.0 x16 1 x PCIe 3.0 x16 (x4 mode) 4 x PCIe 3.0 x1) //one for the GPU). My requirement for the card is: Bluetooth 5.0(or higher), aptx (low latency) and a price under €50.
I already searched trough Amazon, but only found ones with strange brand names like Ziyituod ?
Any recommendations?
oh and my highest priority is for audio b 5.0 and aptx
https://linustechtips.com/topic/1245182-looking-for-a-pcie-bluetooth-solution/
Use a USB adapter.
F@H
GPD Win 2
You're not going to have any luck finding a PCIe card that exclusively has Bluetooth, only cards with both Bluetooth and WiFi capabilities.
I would suggest taking a look at the TP-Link TX50E if you want an elegant solution, though the ASUS PCE-AC58BT would do as well.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
I am using one form Gigabyte, I found it on Amazon, it also has Wifi onboard if that is something that you need to.
https://www.amazon.com/gp/product/B00HF8K0O6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
I'm not aware of any adapter that does both aptX LL and BT5 whether USB or PCIe.
Can see why you'd want aptX LL, but what do you also need BT5 for?
F@H
GPD Win 2
AptX LL on its own gives you low latency, BT5 does not play a role in it.
F@H
GPD Win 2
