Hey all!
I'm looking for some help with a good fan control solution for my case. My 900D is currently packed with 18 fans  :blink:  :blink:  :blink:
Right now I have all these hooked up to some NZXT Grid hubs, which work great for powering the fans. Unfortunately, this give me no fan speed control! (NZXT Grid uses a 3-pin hub-to-mobo connection). This is leaving my system sounding roughly like a jet engine.
I am looking for a solution that will allow me a minimum of two control points (one for radiator fans, one for some/most of the others) and preferably does NOT use a 5.25" drive bay as I would like to keep the front of the case pretty.
I have looked at Corsair Link, but they are very hard to find in stock and I'm seeing mixed reviews on the cooling node.
Any suggestions would be greatly appreciated!!
post-57160-0-69077600-1394174255_thumb.j
post-57160-0-77706100-1394174256_thumb.j
post-57160-0-78535300-1394174257_thumb.j
https://linustechtips.com/topic/124463-best-fan-control-setup/
Maybe 3 of these?
http://www.amazon.com/NZXT-Technologies-Sentry-Controller-SEN-MIX2-M1/dp/B00DN3IT7M/
There's also fancier models with screens and all. Might even want to try using splitters with it to control 12 fans out of each one (never tested this myself though).
I own an NZXT case too and had my fans plugged in to the included grid which runs them at 100%. I now have that exact fan controller for 5 fans and I run 4 off a H100i's Corsair Link.
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
https://linustechtips.com/topic/124463-best-fan-control-setup/#findComment-1655734
https://linustechtips.com/topic/124463-best-fan-control-setup/#findComment-1655737
I would get a fan controller and plug one of the nzxt grids in to each lead from the controller and control the fans on one grid.
https://linustechtips.com/topic/124463-best-fan-control-setup/#findComment-1655761
