Will the length of a usb extension cable affect the latency of a Logitech mouse or keyboard?
I have a G-pro Wireless and Logitech G613 keyboard. I run my computer in my closet about 5 feet away from my desk.
I've read elsewhere, that over 9 feet will make the usb 3.0 cable lose signal.
I bought 10 foot usb 3.0 cables (so I can cable-manage them easier) and a powered belkin usb 3.0 hub to place near my setup where I have the USB dongles for the keyboard and mouse plugged into. The g-pr0 and g613 manual suggests that the mouse be within 20 CM.
here is the cable i bought... usb 3.0 10 foot cable
Should I plug the USB dongles into the front IO of my computer? Or should I buy the 6 foot cable instead? Or should I just use the 10 foot extension cable, plus usb 3.0 hub in my current setup?
This is my first post on the forum. Thanks
Tanner
https://linustechtips.com/topic/1243037-usb-cable-length-latency-issues/
practically, no, it either works or it doesn't. no perceivable latency. but signal might be lost if it's too long of an extension (then it wont work)
and a hub does not add perceivable latency as well.
im using "practically" and "perceived" because theoretically it does add some latency, but it's not noticeable.
-sigh- feeling like I'm being too negative lately
the cable length video, around 3:57 is where it seems the powered usb hub "could bridge the gap" so technically I have surpassed the recommended length, but I wonder if the powered USB hub is actually fixing that issue.
As you mentioned, Moonzy, the perceived loss of latency is something I wont notice. The theoretical possibility isn't reassuring, and makes me want to get shorter extension cables haha.
Do you know anyone who has tested the signal loss for a logitech mouse via distance?
