AIO radiator placement
Solved by Hairless Monkey,
11 minutes ago, lithium_6 said:It usually runs in the high 80°C under load
That temperature isn't to bad 90C+ is where I start to be concerned.
11 minutes ago, lithium_6 said:probably an ML120L from Cooler Master
I wouldn't bother with a 120mm AIO. Many air coolers exist that will easily outperform it. Minimum I'd go for a radiator is 240mm.
12 minutes ago, lithium_6 said:how bad is to place the radiator at the rear exhaust instead of top exhaust?
It would be very similar. Only thing different, is that you should be sure to mount the cooler with the tubes at the bottom, but as I said, a 120mm AIO is not worth it.
