8 minutes ago, Ahsan Ghauri said:
Hello if i put power supply  out of case will it cause problems?
do you mean you want to use the power supply while it is not inside the case? such as it's plugged into the motherboard but is sitting on your desk?
because that would be fine
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1241956-i-need-help/#findComment-13982730
One more thing can i use 24 pin to 12 pin psu adapter and using a rx 560 pci-e only card on acer veriton what problems can occur? Thanks
https://linustechtips.com/topic/1241956-i-need-help/#findComment-13987383
it'll probably work, an adapter is the best case scenario but I don't think you'd need a PCIe only card if you were using a proper PSU with PCIe cables.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1241956-i-need-help/#findComment-13987392
I already bought the card i have no choice....
Will pci-e not be able to provide enough power or it will go boom?
https://linustechtips.com/topic/1241956-i-need-help/#findComment-13987404
i recall some compatibility issues being possible on those motherboards but if you get it working, nothing should go boom.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1241956-i-need-help/#findComment-13987412
