I'm upgrading my PC, and I decided to go with the MoBo ASUS X570 TUF GAMING, I was crosschecking the QVL and the memory kits available here in my country. The best one that I found that is in my budget is the Vengeance LPX 2x8GB CMK16GX4M2Z3200C16, but the QVL states that only the version 4.31 is validated, but I can't check it before the purchase. Should a risk it? What could go wrong if I get unlucky?
NOTE: I could try my current memory set, but I giving this PC to my mother.
Also, I would appreciate some help chossing the CPU. I was thinking about the R5 3600X, but I maybe able to stretch the budget to get a R7 3700X or the 3800X, but I don't want to spend extra just to get a couple more fps. The reviews and gaming benchmarks a looked showed between a a modest and a significant increase in permormance, so I don't know what to expect. I will be paring it with a RTX 2070 Super.
NOTE: I will also upgrade my monitor (from my signature) later
Thanks a lot!
MoBo                           ASUS TUF GAMING X570 Plus/Br
CPU                             AMD Ryzen 5 3600x
CPU Cooler                 AMD Wraith Spire
Memory                       2x Corsair Vengeance LPX 8GB DDR4 3200MHz C16
SSD                             Samsung 850 EVO 500GB
SSD                             Kingston SSDNow V300 120GB
HDD                            Seagate Barracuda 3TB 7200RPM
Video Card                  EVGA nVidia GeForce RTX 2070 Super KO Gaming
Case                           Corsair Carbide 600Q
PSU                            Corsair CX750M
Optical Drive               ASUS DVD RW
OS                              Windows 10 Pro 64-bit
Keyboard                    Corsair K70 LUX Cherry MX Brown
Mouse                         Corsair Sabre RGB
Speakers                     JBL Peebles
Monitor                        LG 23MP55HQ 1080P 60Hz 5ms 23"
https://linustechtips.com/topic/1241165-cpu-and-memory-questions/
