So, I recently installed a Dark Rock Pro 4, and now my PC is performing worse. Temps are great, cinebench, Heaven Engine, and userbench scores are above average; however, I am encountering fps issues in every game, some worse than others. When reinstalling my gpu, one of the power connectors wasn't pushed in all the way when i turned my pc on causing it to freeze, and another time the pcie clip got stuck, but I was eventually able to push it back freeing my gpu. However, even though my installation wasn't the smoothest, my computer is performing so well in these benchmarks, which makes me assume it is a driver issue maybe? The most notable is in Ori and the Will of the Wisps, which will have tons of frame drops and averages around 180 fps when it was easily above 230 before. All other games are below average by around 20 fps. I DDU my drivers and did a fresh reinstall of windows, which still didn't help. Out of desperation, I updated my bios with no avail. It arguably made it worse cause now my gpu usage is low and my cpu usage is high. My frames are worse in some games more than others now too. I am just so confused because the PC ran flawlessly before I installed the cooler with the same drivers, etc, but now it performs well below what it should be reaching, but then it performs great in benchmarks where the gpu reaches 100% utilization. Any help is much appreciated!
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1240741-low-gpu-usage-and-high-cpu-usage/
