Just a week or two ago i checked my CPU temp again and it seemed pretty high.
i'm using an AMD Ryzen 7 3700X with the stock cooler and am getting around 60 degrees idle,(it used to be 35-45).
I checked task manager and it said that the CPU usage was only at 15%.
Please help.
https://linustechtips.com/topic/1239756-cpu-temps-suddenly-high/
And what are load temps? if load temps are similar/ good then don't worry about it for the most part, idle temps do not matter, load temps do.
Phone: Pixel 3a (Purple-ish).
Build Log:
Please help.
How old is the pc? If it’s a few years old the stock thermal paste might need replacing
10 hours ago, lucas bushnell said:
and while doing it my CPU reached 95C which is very high.
first of all please don't use user benchmark, second of all, what cpu and cooler and what are you using to monitor temps.
and ambient temps? case airflow?
Build Log:
I did a Userbenchmark (https://www.userbenchmark.com/UserRun/32290231) and while doing it my CPU reached 95C which is very high.
Do you have any sort of overclock on your cpu? You should try to repast and reseat the cooler.
Also, avoid userbenchmark. I guess it’s fine for putting the cpu under load, but the scores are meaningless.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
I didn't overclock my cpu
Start simple
- dust out the stock cooler and rest of the case and make sure the fan plug is seated properly;
- if that doesn't improve things, inspect the fan to ensure it's spinning properly;
- if it is, check the fan curve in your BIOS in case you have it set to some sort of silent mode where the fan speed doesn't ramp up unless really hot;
- if all is normal on that front, replace the stock thermal paste, perhaps it went bad;
- if no improvement after all that effort, invest in a better cooler.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
1 minute ago, IrshaadH said:
Start simple
I was just thinking of doing that
