AIO FAN Help!
Go to solution Solved by jones177,
I liked this video for AIO placement.
Hello, so I got the Corsair Hydro Series H100i RGB platinum 240mm radiator.
For my case I have 6 fans total. 1 on the back, 2 top, and 3 in the front.
I need help as to where I should install it.
Should I install as an exhaust on the top (of the case) and make the back fan also exhaust and make my 3 front fan intake?
OR
Should I make my top 2 fans and 1 back fan exhaust and make the front 2 fan AIO with the other front fan as intake?
Hope it makes senses. What should I do?
https://linustechtips.com/topic/1239061-aio-fan-help/
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1239061-aio-fan-help/#findComment-13960806
1 hour ago, Caroline said:
Front would be the best but what's your case?
I'd remove the rear fan as well and keep the exhaust at the top
My chase is Phanteks Eclipse 400s. It has 6 fans. I plan to use all those 6 fans. I just need to know where I should place radiator (AIO). Front or top?
I may do the back fan exhaust, radiator at the top as exhaust, and 3 fans in the front intake.
https://linustechtips.com/topic/1239061-aio-fan-help/#findComment-13960969
