Are you sure that you know what exactly you are doing? I dont generally reccomend people playing with power tables and such on laptops :P What do you mean it was too aggressive?
Let it change clocks automatically, if you're undervolting with BIOS just use a negative voltage offset.
btw you can try this out as well
Just lower the voltage in the tool, should be more managable than the BIOS or Ryzen Master
Desktop benching:
i mean it's a laptoop using a desktop cpu,once the temperature is too high the fan goes noisy,that's why i undervolt
should i keep all cores at the same frequency when using ryzen master
Let it float around
Desktop benching:
