hi i have a i5 3470 8 gigs ram and a 240 watt power supply  and i want a graphics card bc im running integrated and i was thinking a geforce zotac 710 i dont have a ton to spend and my power supply and case size are problems as well
my pc: https://www.amazon.com/HP-8300-Elite-Computer-Quad-Core/dp/B01CV9G1BO/ref=sr_1_19?dchild=1&keywords=hp+i5+8+gigs+ram&qid=1598401307&sr=8-19
geforce 710:https://www.amazon.com/dp/B01AZ7W88O/?coliid=I3QO7OQFYCFG84&colid=1EMTOELZ1NP9G&psc=1&ref_=lv_ov_lig_dp_it
https://linustechtips.com/topic/1238751-help-i-need-help-upgrading-my-pc/
The lowest end GPU I can recommend for gaming is a GTX 750 TI. Anything lower, like the GT 1030, is just terrible value. You can run a 750 TI on a pretty low end power supply with no issues, and I'm pretty pleased with the performance of mine.
Primary PC:
PSU tier list
How many watts do I need?
6 hours ago, vortextech77 said:
I think your main upgrade priority should be to save up and get a new PSU
unfortunatly, he cant upgrade the power supply as it is a proprietary psu, and i highly doubt he will find a reliable one that fits inside his pc
yes, the gtx 750ti is your best option, gt 710 is not gonna be enough at all to play even some esport games, but the problem is finding one the small form factor, as they are really expensive compared to the normal sized gtx 750ti
I already recommended a new case and PSU since OP's motherboard fits in a standard case.
Primary PC:
PSU tier list
