My pc has different brands RGB components and I would like to sync them together so for this, I have installed Jacknet Rgb software but whenever I’m trying to start it, it opens in the taskbar and then automatically close.
After installing it I have restarted the pc, enabled sdk for corsair icue AIO, installed aura sync but it is not working..
https://linustechtips.com/topic/1237763-jacknet-rgb-not-working/
This?
Quote
There are a few bugs with the latest RGB.NET version (JackNet 1.7.6+), and you can either revert to Jacknet 1.7.5 and wait for an update that fixes these bugs or, try remaking your profiles / group LEDs.
For any of these less known software, use their help/forums first. As basic troubleshooting, run as admin, disable AV and so on.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
