PC power button does not work after shutting down.
I have a Cyberpower PC from best buy
Specs:
AMD ryzen 2300x
Rx 570
240 SSD + 1 TB
8gb Ram
The problem I have is that my pc turns on but after a shut it down I have to either unplug the power cord or flip the power supply off for about 5 seconds before the power button works to turn it on. Do you know how to solve this? Its a brand new pc
Specs:
AMD ryzen 2300x
Rx 570
240 SSD + 1 TB
8gb Ram
Brand new system should go back to the store for exchange.
But if you're up to it... trace where the power button is plugged into the motherboard.  Take off the connector and touch the two pins with the tip of your screwdriver.  Does it turn on?  If so, the power button is broke.  If not, there's a problem with the motherboard.  There's a slim chance that the problem is with the PSU, e.g. low power good signal.
Take it back to Best Buy...
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
