Hi guys,
I don't know which cooling is really better for my CPU air cooling or water cooling? can you guys help
I got two systems to which I must put a cooler before moving on:-
1. Core i9 10900k
2. Amd Thread Ripper 3990x
I was thinking of the Dark Rock 4 pro 50.5 CFM for 10900k
I was thinking of the Dark Rock Pro TR4 59.5 CFM for 3990x
I really recommend your experience
https://linustechtips.com/topic/1236946-air-cooler/
The Dark Rock Pro 4 will cool both of these well without breaking the bank. Good choice.
I used it before and was really happy with it.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1236946-air-cooler/#findComment-13944223
