Off to University next month and my FD ARC XL case is too large and bulky to transport for a university dorm. Goal is to minimise space, look professional and ideally fit everything though if I have to part with my cooler I understand.
Specs:
i74790k
z97 gaming 5 motherboard full ATX
2070 super (Ik bottleneck... it’s for when I change to a laptop + enclosure eventually..)
x62 kraken CPU water cooler (I want to keep this as a OC to my CPU is required to make use of the card.
then the rest doesn’t matter I believe
https://linustechtips.com/topic/1236459-help-with-picking-a-case/
Specs:
i74790k
try getting a cooler master td 500 mesh , its got 3 rgb fans (for 10000+ fps)
or try getting a fractal meshify c or cooler master 275r airflow if u arent into rgb fans
there are plenty more of cases i can recommend
