Hi everyone I've had this problem for awhile and I was hoping I could get some help with solving it. Here's what's happening: So if I do happen to be gaming when it happens both of my screens go black for a second, my game closes, and then the windows I have open on my second display kind of disappear leaving the outlines of the windows. Then everything goes back to normal. Then after some random amount of time like 10 seconds-2 minutes, my PC will crash. Sometimes I get a BSOD that gives the message "Video_TDR_FAILURE (atikmpag.sys), other times my primary display goes black and my secondary display goes green, and other times it just restarts. I feel like this is some sort of graphics issue based on what is happening. My system specs are:
AMD Ryzen 3600
G.Skill Ripjaws V 2*8gb @3200mhz
MSI b450 Tomohawk MAX (Latest Bios and chipset drivers, problem was happening before updates)
Powercolor Red Devil 5700 xt (Driver version 20.7.2, problem has happened on every driver version I've tried)
Samsung 860 EVO
Seagate Barracuda
Corsair RM650x
Windows 10 1909
I've looked through event viewer and found errors like:
A problem has occurred with one or more user-mode drivers and the hosting process has been terminated.  This may temporarily interrupt your ability to access the devices.
The device HID-compliant headset (location (unknown)) is offline due to a user-mode driver crash.  Windows will attempt to restart the device 5 more times.  Please contact the device manufacturer for more information about this problem.
A timeout was reached (45000 milliseconds) while waiting for the AMD External Events Utility service to connect.
The AMD External Events Utility service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
Mesh Devil
AMD Ryzen 3600 | MSI b450 Tomohawk MAX G.Skill Ripjaws 2x8 3200mhz
Powercolor Red Devil RX 5700 xt
Samsung 860 EVO 500 GB | Seagate Barracuda 2 TB
Corsair RM650x
Fractal Design Meshify C Tempered Glass
https://linustechtips.com/topic/1234449-random-system-crashes/
Definitely sounds like a driver issue. Download and run DDU (Display Driver Uninstaller) and remove all AMD drivers. After a reboot, reinstall the latest drivers from AMD and see if that helps. If not, I would suggest RMA'ing the card, seeing as how it's still fairly new.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1234449-random-system-crashes/#findComment-13923137
Unfortunately reinstalling the drivers didn't help. It happened again with the same exact errors in event viewer. Is there anything else you would recommend trying before RMA'ing?
Mesh Devil
Corsair RM650x
https://linustechtips.com/topic/1234449-random-system-crashes/#findComment-13936863
