Overclocking help!?
Go to solution Solved by Perrytheplatypus43,
So what i do is get a gpu stress testing program. So first start bumping up all the parameters by 10: the memory clock speed, core clock speed, and core voltage. after you have done that run the stress test for about 2-5 min if you see everything is stable and you see no artifacts then repeat the process until you hit the max. for OC software i would use MSI After Burner (scroll to the bottom for download) and for the stress test i would use MSI Kombustor
Hello everyone,
I need help with overclocking GPU, my specs are:
Motherboard: Z87X-D3H
CPU: Intel Core i7 4770 3.40Ghz
RAM: Kingston HyperX Fury 1600mhz 2x4Gb
GPU: nVidia GTX 770 2Gb
PSU: Thermaltake Smart SE 730w
SSD: Kingston HyperX 120Gb
HDD: 1,5Tb WD Black
So here is the thing. I am not really an overclocking geek so I need your help guys, I need to know how far can I go with my GPU in ASUS GPU TWEAKII and what do I need to know, its kinda older GPU but I want to get max from it. Here is my GPU: {https://www.asus.com/Graphics-Cards/GTX770DC2OC2GD5/}; I sent 3 pics to show you my IDLE status of GPU, so if is anyone there who can explain me something about OC and give me some steps or profile what can I do I would be pleased.
Thanks!
https://linustechtips.com/topic/1234044-overclocking-help/
CPU: Intel Core i7-9700K 3.6 GHz OC 4.7GHz 8-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte B365M DS3H Micro ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL20 Memory
Storage: Crucial MX500 500 GB 2.5" Solid State Drive
Storage: Western Digital RE2 400 GB 3.5" 7200RPM Internal Hard Drive
Storage: Western Digital Caviar Blue 640 GB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 1050 3 GB SC GAMING Video Card
Power Supply: Antec NeoECO Gold ZEN 700 W 80+ Gold Certified ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit
Monitor: Dell ST2410 24.0" 1920x1080 60 Hz Monitor
Monitor: NEC LCD1960NXi 19.0" 1280x1024 60 Hz Monitor
Keyboard: Alienware AW768 RGB Wired Gaming Keyboard
Mouse: Microsoft Intellimouse Pro - White Shadow Wired Optical Mouse
Headphones: Sennheiser HD 280 PRO  Headphones
https://linustechtips.com/topic/1234044-overclocking-help/#findComment-13919470
