8-way rack mountable PC reset solution, HELP!
Jcowley
I am in need of some hardware and cannot find anything to suit my needs so I thought here might be the best place to ask, even if it's not 100% appropriate. I need a rack mountable unit that interfaces with the front panel power/reset/status pins on a desktop motherboard.
I need to be able to reset and force shut down up to 8 PCs on a single unit and it cannot be a PDU as it needs to also show the power/reset status of the PC.
Any help you can offer me would be greatly appreciated :)
