Budget (including currency): 27,000 PKR (roughly $160 USD)
Country: Pakistan
Games, programs or workloads that it will be used for: Only for gaming with games like Modern Warfare, BF5 and other similar games like the upcoming CoD
Other details:
Existing Parts:
GeForce GT 730
Intel core i5-3470S @2.9GHz
12 GB RAM
230V PSU
500 GB
1 TB HDD
I am aware that it is hard to fit anything in my budget but if the cheapest suitable improvement option is a little more expensive then still pls tell me. I do not need any peripherals, I have a single 1600x900 monitor but I would be happy with 1080p resolution 60 fps gaming. Currently in CoD modern Warfare, the fps drops to as low as 7 with an average of 18 (at the lowest possible graphic settings ofc) even after decreasing the display resolution to around 1360x768. FPS climbs to 35 at the lowest 800x600. I know that I need a new GPU but I just needed advice on which one I should buy and whether anything else would cause a bottleneck like my 3rd gen processor or if my PSU is unsuitable. I had the 1050ti in mind which fits the budget but if there is some other component which also needs to be improved then pls tell me. While gaming, my memory and CPU usages are 75% and 95% respectively. I am aiming to buy asap as I think prices are increasing due to the pandemic (correct me if I am wrong). Any help would be much appreciated.
P.S
I think prices are relatively higher in my country due to customs taxes and what not so pls take that into consideration.
https://linustechtips.com/topic/1232708-pc-upgrading-help-required/
11 minutes ago, Snarky said:
Rx 580 will get bottlenecked
a 1050ti or rx 570 is perfect for this job
I would recommend the rx 570 if you got a powerful 500w+ power supply
Also consider upgrading your cpu
upgrade to what? an i7 or a higher gen i5? also RX 580 will get bottlenecked due to the CPU right?
So? It's an investment in the future if you want to get a better cpu.
Everything will be bottlenecked one way or another, don't worry about it.
Get the best GPU you can afford.
should I go for a 4GB or 6GB one? or do these not really matter?
there's no 6gb, 8gb you mean. more vram the better.
with more vram you can use higher quality preset.
