Hello, I'm having some trouble and I think that although the fix is easy, I cannot find it.
I built my new system on a MSI MAG b550 Tomahawk with a Ryzen 5 3600 Cpu, and it seems to work, I entered BIOS and all is well.
However, the USB i plugged into the motherboard (To install Windows10) is not showing in the Bios boot priority, and when I enter the boot mode (F11) it simply shows "Please select Boot device:" but no boot device is shown and the only option is "Enter Setup" which takes me back to the BIOS. There is a feature in the BIOS called Board explorer which shows me what is on the Mobo, such as my RAM and Cpu and all that, but there is no USB shown in the usb slot I entered my flash drive.
My problem is, then, I cannot find how to add my USB to the boot priority to boot up the Windows 10 installer, Please help!
https://linustechtips.com/topic/1232590-usb-not-found/
How did you create the installation media for Windows 10?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1232590-usb-not-found/#findComment-13907502
I only have a Macbook pro, so I downloaded the windows 10 installation media onto a flash drive from the Macbook pro using this youtube tutorial which is 1 minute long lol
https://linustechtips.com/topic/1232590-usb-not-found/#findComment-13907505
Try using Bootcamp instead, see https://www.thewindowsclub.com/create-a-windows-10-bootable-usb-on-mac.
Desktop
Homelab
https://linustechtips.com/topic/1232590-usb-not-found/#findComment-13907515
6 minutes ago, AgelessWonder10 said:
Using Bootcamp simply prompts me to download the ISO onto my own Mac, so I know that the ISO works (right?)
Once it reaches the point where it prompts you to make a new partition on your Mac, the installation media should have been successfully created. You can verify this by checking if the name of the flash drive is now named WININSTALL. If the name matches, you should be able to boot to it.
Desktop
Homelab
https://linustechtips.com/topic/1232590-usb-not-found/#findComment-13907548
Thanks, I am redownloading the Windows iso, I will respond again when it is done in an hour
https://linustechtips.com/topic/1232590-usb-not-found/#findComment-13907557
