I recently built my computer with a ryzen 5 3600 gskill ripjaws 16 gb 3600mz and a msi tomahawk b450 max and I have the CPU and DRAM red lights on my motherboard. My monitor will not pick up signal from my PC and I have checked my CPU and ram and have not spotted anything wrong with either of them. Is there something I can do?
https://linustechtips.com/topic/1232253-cpudram-red-lights/
CPU: Intel Core i7-9700K 3.6 GHz OC 4.7GHz 8-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte B365M DS3H Micro ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL20 Memory
Storage: Crucial MX500 500 GB 2.5" Solid State Drive
Storage: Western Digital RE2 400 GB 3.5" 7200RPM Internal Hard Drive
Storage: Western Digital Caviar Blue 640 GB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 1050 3 GB SC GAMING Video Card
Power Supply: Antec NeoECO Gold ZEN 700 W 80+ Gold Certified ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit
Monitor: Dell ST2410 24.0" 1920x1080 60 Hz Monitor
Monitor: NEC LCD1960NXi 19.0" 1280x1024 60 Hz Monitor
Keyboard: Alienware AW768 RGB Wired Gaming Keyboard
Mouse: Microsoft Intellimouse Pro - White Shadow Wired Optical Mouse
Headphones: Sennheiser HD 280 PRO  Headphones
https://linustechtips.com/topic/1232253-cpudram-red-lights/#findComment-13904713
make sure your monitor is plugged into the GPU
could:
- clear cmos
- try reseating the ram
- try 1 stick of RAM in each slot
- try reseating the CPU (twist and tilt cooler gently before pulling up)
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1232253-cpudram-red-lights/#findComment-13904745
could:
- clear cmos
I am fairly new to computers so if you don’t mind me asking how do I clear cmos
https://linustechtips.com/topic/1232253-cpudram-red-lights/#findComment-13904775
first, shut down your computer, and power off your psu
then:
- find the CLR_CMOS pins (normally on the bottom right of the motherboard, consult motherboard manual to be sure) and short the two pins with a screwdriver for 3 seconds
or
- find a round silver thing that is about 6/8 inch / 20mm in diameter (near the middle of the motherboard most of the time), push a little silver tab at one of its side and the button cell will pop out, wait for 2 minutes before re-inserting it, smaller face side down
https://linustechtips.com/topic/1232253-cpudram-red-lights/#findComment-13904782
