should i need  a bigger power supply for a 7770 video card
mid tower case
AMD 1055T 2.80GHZ WATER COOLING TURBO ON NOT OVERCLOCKED
WINDOWS 7  64 BIT
1 TB
5770 1gb
GIGABYTE GA-770T-USB3
KINGSTON HYPERX from 8gb to upgrading to 16
700 WATT
with 2 displays 1440/900
https://linustechtips.com/topic/12314-power/
700 watts is huge for yout setup. Don't stress. ;)
Desktop - Custom watercooled R4E/i7 3930k/GTX 780 SLI/32gb 2400mhz DDR3/Xonar STX/OCZ V4 256gb RAID 0/24tb RAID 5
Laptop - Clevo P370EM - i7 3630QM/GTX 680M SLI/8gb 1866mhz DDR3/840 pro 256gb RAID 0/750gb mechanical
https://linustechtips.com/topic/12314-power/#findComment-131437
You can if you want to but there's no reason why it's necessary.
In short - No.
https://linustechtips.com/topic/12314-power/#findComment-131485
700w can run your gpu. This psu could even run a 7950.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/12314-power/#findComment-133085
