I have just built my rig and the ryzen cpu doesn't seem to be right but I'm not sure as I'm new to this. The games I have played so far are running right but my cpu is stock at 3600mhz but looking at the cpu on the ryzen master software the cpu is hitting over that on peak speed. When i run cinebench the PPT reading goes red and off the chart. Also the buzzer in my pc keeps on going off when playing games im guessing when the peak speed is too high. Any help really appreciated!
My build
Ryzen 3600
Stock Cooler
Corsair RM 650
Aorus X570
16GB Corsair Vengeance
Edited by Wilmotheworm
Forgot to put info in
https://linustechtips.com/topic/1231311-new-ryzen-cpu-problem/
Just now, Wilmotheworm said:
buzzer in my pc
Wait what?
You can just do some overclocking in the bios
or just set the speed to like 4400mhz at 1.375V max for daily use.
https://linustechtips.com/topic/1231311-new-ryzen-cpu-problem/#findComment-13897074
