Hey guys, I'm new here. Hoping anyone here can help me out with my issue, or at least explain what is going wrong.
So about a week ago I purchased an RTX 2070 Super. Excited to play games at higher FPS and better settings I came across a bit of a speedbump.
It turns out about 10 to 20 minutes into a session (usually graphically intensive games. Think Modern Warfare, Forza Horizon 4, Death Stranding.) my CPU will suddenly spike in usage and start to underclock itself, and then reset itself back to normal speeds. (From around 4400MHz down to 800MHz and back up) Causing heavy frame rate drops for a couple of seconds.
Things I've tried to do in order to combat this:
Re-applied thermal paste
Deleted, and reinstalled graphical drivers
Bought a new cooler thinking the old one simply couldn't keep up anymore
Lowered game settings
None of these things seemingly helped me fix the issue...
My specs (Taken from Speccy):
Operating System
    Windows 10 Pro 64-bit
CPU
    Intel Core i7 7700K @ 4.20GHz
    Kaby Lake 14nm Technology
RAM
    16,0GB Dual-Channel Unknown @ 1066MHz (15-15-15-36)
Motherboard
    Gigabyte Technology Co. Ltd. H110M-S2PV-CF (U3E1)
Graphics
    4095MB NVIDIA GeForce RTX 2070 SUPER (Gigabyte)
Storage
    465GB Seagate ST500DM002-1BD142 (SATA )
    931GB Seagate ST1000DM003-1CH162 (SATA )
    465GB Samsung SSD 860 EVO 500GB (SATA (SSD))
I was using a GTX 1060 before getting a new GPU.
I have attached screenshots of HWMonitor as extra information. If there is anything else you'd like to see/know let me know and I'll send that too.
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/
I'm wondering if the VRMs are overheating and the CPU is clocking back because of that. An i7 is a lot to ask from a base-tier H110 board like that (besides the fact you can't overclock on it).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890764
The thing I'm failing to understand is why is it suddenly now an issue. Everything worked fine with my GTX 960 and 1060.
So do you think the motherboard is the weak point here?
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890804
bought the best gaming cpu thats also unlocked (assuming you bought it when it launched) and a cheap h110 motherboard????
come on bruh
99% sure this motherboard just cant keep with that 7700k on high clocks and since you have a 2070, the cpu does have to work a bit harder even though its a 7700k
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890833
haha whoops
Any recommendations for one which can?
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890839
7 minutes ago, Lonkkil said:
haha whoops
sure
try looking for high end z270 motherboards
Gigabyte Aorus Z270X Gaming 5
ASUS PRIME Z270-A
Asus ROG Maximus IX Formula
those are the top end motherboards and since z270 chipset is 3.5 years old im sure you can get those motherboards for a good deal
intel has this stupid thing where only the 'Z' chipset (z170, z270, z370, z390, z490) supports overclocking while amd has 'X' and 'B' (x570, b450, b550)
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890849
2 minutes ago, HardStroke said:
sure
ASUS PRIME Z270-A
Hmmm, I'll look into it, thanks mate.
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890854
if those motherboards are still expensive my personal recommendation is Gigabyte's GA-Z270-Gaming K3
a friend on mine has it and its working with no problem, even when his 7700k is turboing
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890858
I think I'll have to go for that one yeah. Already spent way more money on all this than I originally intended to lmao.
https://linustechtips.com/topic/1230512-gpucpu-combo-issues/#findComment-13890869
