if you search for partitioning (or partition) in your windows settings it should show a control panel setting called "create and format drive partitions" (that was directly translated from the result i got on windows with danish language.
then you should see your drive and the unallocated space.
then you can allocate space from there
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888818
Great, so i've done that now.
Any ideas on how i combine them? Just do i dont have two seperate drives on one disk!
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888838
it's a while since i've done it and i'm on a work computer so i can't just format part of my own drive to check.
but i belive if you right click the part that's already allocated, there should be an option called "expand disk"
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888844
Option is there, but its greyed out! how annoying
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888865
You might need to get rid of the second empty partition to do that. :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888880
oh, it's because you made your boot partition 446GB.
normally you don't need that much space just for windows
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888896
Done! but still no luck, anymore suggestions? it doesnt let me merge the two!
It might be because the recovery partition is after the main partition. You might need to remove (or maybe move) that partition in order to expand it. Try if it can expand onto that partition first (but don't do it)
But according to your picture your partition D is still allocated, you first need to unallocate it to add it onto another partition.
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888913
1 minute ago, owencrispy said:
Ah! any idea how i change that?
I don't think you can merge partitions with the partition that has windows on it.
I could be wrong but i've had some issues with that before.
https://linustechtips.com/topic/1230325-drive-help/#findComment-13888980
