Hey all
I've got a rather odd problem
So my employer has asked to build a rather expensive pc,
With a couple requirements
So the general specs are as followed:
msi trx40 creator
amd 3970x
coolermaster ml360 rgb tr4 edition
kingston 128gb hyperx 3200mhz
corsair mp600 1tb
samsung qvo 4tb
2x msi 2080 super gaming x trio + msi nvlink
be quiet 1200w dark power
Ok so we build the pc installed it and it works BUT,
since i wanted to verify that everything worked i ran 3dmark.
And thats when the odd thing happened.
The timespy bench only got a score of about 11k but does see that there are 2 cards, yet another system with those 2 cards had a score of about 18k.
However during port royal it does get the same scor as the other system  wich is around 13k.
Nvlink is on and visable and the settings for 3dmark where te same for both systems.
Been testing some stuff but sofar nothing changes and i no longer know what it might be.
Hope some of you have some suggestions.
p.s. we are located in belgium
Not looking for parts advice unless it might fix the issue.
Greets
Amari
https://linustechtips.com/topic/1230314-odd-nvlink-problem/
What his computer will be used for? That nvlink bridge may end actually being useless, as most software that actually makes uses of multi-gpu won't care about it. Best case scenario you'll get a 10% boost.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889859
yes i relize that, but this doesn't change the fact it should be working for 3dmark since i had it work before.
the use of the pc is not rly the issue ( it wont actually be used asfar as i know, but its orders from the boss ;) so i just need to make it work )
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889881
May be a weird quirk with 3dmark, who knows. As you said, it did work with other benchmarks, maybe you could try some other ones and forget about that weird 3dmark result?
Lenovo N23 Yoga
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889890
With Time Spy you need to break down your score to see where you are deficient.
With my setup below I usually get a score of 14.5k in Time Spy. The graphics score is 16311 and the physics score is 9023. Your graphics and physics scores should be higher. The one that is not is where your problem lies.
In my experience with Port Royal I find that my CPU overclock does not matter at all so it is a purely a GPU test. I get a much higher scores compared to others in Port Royal than I do in Time Spy since I am not competing against LN2 users as much.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889904
It might be a quirk yes i have not use another bench sofar since i never had issues up till now.
the gpu scoré was the odd one out thats why im leaning towards nvlink issue
for the record only thing we didnt swap out yet is the bridge since we cant get a new one atm ( seems to be sold out almost everywhere)
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889921
You could give a try with mgbench or tensorflow benchmarks. Those should work regardless of the nvlink bridge.
Lenovo N23 Yoga
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13889943
Nvidia has them in stock.
https://linustechtips.com/topic/1230314-odd-nvlink-problem/#findComment-13890008
