I currently have a CSE-846E16-R1200B (with a LSI 9211-4i & BPN-SAS2-846EL1)
I was considering dropping a 3900x build into it, but noticed that that I might not be able to fit a full modular power supply into it. Does anyone have this case, and were you able to fit a full size PSU into it? (Example: Corsair HX850) or should I just use the built in power supply (2x1200w) that came with the case?
Full build
  1. Processor: 3900x
  2. RAM; 64GB 3600mhz / Up for discussion - Possible ECC memory slot
  3. Power: Corsair HX850 // 2x1200w Gold+
  4. Motherboard: ROG Strix x570-E / Up for discussion - looking for an AM4 ECC-supported motherboard
  5. Controller: LSI 9211-4i HBA JBOD FREENAS UNRAID
  6. Backpane: BPN-SAS2-846EL1 24-port
  7. Case: CSE-846E16-R1200B
  8. MAYBE: 1080Ti -- I only glanced at the wires stemming from the power supply shroud, but I didn't notice any 8pins. Does anyone have any suggestions if I wanted to add a graphics card to the server for passthrough/encoding?
https://linustechtips.com/topic/1228146-question-about-chassis-psu/
