Budget (including currency): $7000 AUD
Country: Australia
Games, programs or workloads that it will be used for: Redshift Rendering (24/7)
Am putting together a powerful rendering PC build. Aside from maybe a few basic tasks like web browsing, the computer will be completely dedicated to running Redshift Rendering around the clock. Parts:
CPU: Ryzen Threadripper 3960X
GRAPHICS CARD: Asus GeForce RTX 2070 SUPER (x2)
MOBO: Gigabyte TRX40 Designare
RAM: Corsair Vengeance LPX (2x16) 32GB 3000 MHz (x2)
CASE: Be quiet! Dark Base Pro 900 Rev2
CPU COOLER: Corsair iCUE H115i RGB PRO XT Liquid CPU Cooler
PSU: Corsair HX850
OS will be Windows 10 and peripherals should be something along the lines of two 27" LCD monitors and a standard keyboard and mouse. Also looking to just install a simple 256GB SATA SSD for storage.
Is the 850W power supply is powerful enough and is the 3000MHz fast enough ram?
Is this a good set of parts for the task or are there better configurations considering the budget?
https://linustechtips.com/topic/1226828-redshift-rendering-pc-help/
