I am just building my new PC, my first but and I have been having the same error Code 02: Post Error. I first get the HDD code 02: Post Error, for this I go into the Bios to disable the sata ports and reboot. Then when rebooting I get the VGA Code 02: Post Error. On the BIOS it say there is  a CPU Fan error, but I checked twice and I am sure I connected the AIO Pump correctly. Any idea why this is happening and how it can be fixed?
Specs:
Asus Crosshair viii Formula x570 (Currently using Bios version 2103)
AMD 3600 XT
H100i Pump
AMD Rx 580
32 GB Corsair 3600 Vengeance MHz
M.2 NVME 1 TB Sabrent Gen 4
Seasonic 650 GX
I am currently using a tv instead of a monitor, I will try to do it again tomorrow on a monitor to see if it works because I read that the monitor can be the issue.
https://linustechtips.com/topic/1225663-code-02-post-error/
