Wifi doesnt work when...
Solved by Balvinz0r,
16 hours ago, Mchedlo said:I re-installed drivers for wifi adapter. Reset wifi router a lot of times
cant find anything on google
Try to download from the internet the iobit driver booster driver and see if it will work. most likely from what I think, there is interference where you have the router placed. and I speak like high waves. try moving the router in another location. let me know
