What are you planning on getting exactly?
Also are you looking at an Intel cpu. Because 2933 is the official spec sheet before you technically overclock the imc. Though getting something above that is totally fine. As the imc will handle it.
26 minutes ago, jumbo9i0 said:
if im not planning to overclock memory speed?
Xmp isn't really an overclock imo.
Phone: Pixel 3a (Purple-ish).
Build Log:
1 minute ago, alatron978 said:
XMP by definition is an overclocking technology
I know. Technically it is. Though in the real world it's pretty simple.
Build Log:
