Squid Setup not working. Please Help.
Go to solution Solved by Poet129,
1 hour ago, Poet129 said:
  Reveal hidden contents
Anyone?
After Troubleshooting only Google Chrome is affected by this everything else works as it should.
acl localnet src 192.168.1.0/24
acl step1 at_step SslBump1
ssl_bump peek step1
ssl_bump bump all
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl CONNECT method CONNECT
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow localhost manager
http_access deny manager
http_access allow localnet
http_access deny all
http_port 3128 ssl-bump cert=/usr/local/squid/certs/squid-ca-cert-key.pem generate-host-certificates=on dynamic_cert_mem_cache_size=4MB
sslcrtd_program /usr/local/squid/libexec/security_file_certgen -s /usr/local/squid/var/logs/ssl_db -M 4MB
coredump_dir /usr/local/squid/var/cache/squid
cache_dir ufs /usr/local/squid/var/cache/squid 100000 16 256 # 100GB as Cache
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern . 0 20% 4320
Is my current config however only HTTP is working. HTTPS Error "ERR_CONNECTION_CLOSED". Any help is much appreciated.
https://linustechtips.com/topic/1224738-squid-setup-not-working-please-help/
ssl_bump peek step1
ssl_bump bump all
Anyone?
