Posted July 19, 2020 My CPU recently died and I need a new one for my editing rig, reccomend any other CPUs you want to. A Motherboard pairing for a CPU would be helpful! Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 That doesn't say a whole lot. Technically a 3970x would be the "best". Budget? What are you pairing it with? PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837739 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Author @TofuHaroto I can spend around ±2000 for CPU, MOBO, Cooling. This will be with a 2080Ti and 64GB RAM. This purchase will also be in preparation for new Graphics launches later this year. Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837749 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 2 minutes ago, housingcoin said: can spend around ±2000 for CPU, MOBO, Cooling. Then you most likely won't be able to fit a 3970x. So that's out of the conversation. What are they all priced at where you live? I wouldn't consider the 10980XE unless you're doing AVX workloads. So it's either am4 or trx40. Or just waiting for zen 3 and seeing what that has to offer. If the build is planned later this year. Just wait for zen 3 and check what it has to offer. PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837759 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Author @TofuHaroto the 3970x is about 1850 for me, which leaves it in the "±" range. I am in a debate with myself on whether or not I should wait until the new processors release for either a discount or better CPU at the same price range. Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837767 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 1 minute ago, housingcoin said: not I should wait until the new processors release for either a discount or better CPU at the same price range. If you can wait. This won't hurt to do so... PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837769 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Author @TofuHarotoDo you have a guess on when the new Threadrippers will become available? Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837773 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Just now, housingcoin said: TofuHarotoDo you have a guess on when the new Threadrippers will become available? We really don't know and we can't know. Usually TR releases down the line. But zen 3 should be released at around September or so. PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837774 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Author @TofuHarotoHow many months do you think it will be? Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837779 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 10 hours ago, housingcoin said: How many months for TR? we do not know. for zen 3. maybe 2-3 months. PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837800 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 19, 2020 Author @TofuHarotoAlright, Thank you for your help! Link to comment https://linustechtips.com/topic/1224030-need-help-choosing-a-cpu/#findComment-13837802 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
