Xonar DX power connector
WillLTT
Theres an additional power connector needed on the asus audigy dx, an 4pin floppy connector or something, can someone point me to a long normal power cable to this card that is almost guranteed to work?
i dont want to buy wrong stuff again
Sure, here's a Molex to floppy one: https://www.ebay.co.uk/itm/5-25-4-Pin-Molex-To-3-5-Floppy-Drive-FDD-Internal-Power-Cable-Adaptor/350852253454
Or if you prefer SATA: https://www.ebay.co.uk/itm/SATA-15-Pin-male-To-4-Pin-Female-FDD-Floppy-Adapter-Hard-Drive-Power-Cable-20cm/303501629537
1 hour ago, WillLTT said:
will this cable work with
this one?
Not 100% sure - seeing it again, the photo is a little blurry on the extension one. Possibly might have the wrong connector gender on one end? Might be easier to find a cable to extend the larger 4 pin Molex instead? Will your PSU ones definitely not reach?
i thought so too,
also good idea on the molex, but it seems all molex cables are like 50cm
