Deepcool MATREXX 55 MESH with 4 ARGB Fans
AMD RYZEN 5 3600 (Upto-4.2GHz, CORES-6, THREADS-12)
MSI B450 TOMAHAWK MAX
INNO3D RTX 2070 SUPER TWIN X2 OC 8GB SMPS
GIGABYTE B700H 80 PLUS BRONZE
Samsung 250 GB 860 EVO M.2
Seagate 1 TB BARRACUDA
T-Force DARK Zα 16GB (8X2) DDR4 3600 Mhz GAMING (FOR AMD)
Deepcool GAMMAXX L240 V2 RGB Lighting
suggest me some changes in this build so I can cut down the price
The wattage is pretty high, if you can find a 500 watt model of the same PSU it would be a great cost saver and you still have a lot of room to upgrade.
The motherboard could be a bit cheaper, almost any of the MAX motherboards are pretty good. Pick one with a VRM heat sink for good CPU power delivery and you're set.
Get rid of the gammaxx cooler, the stock cooler is adequate.
The Evo series of SSDs is pretty overpriced for a gaming machine, getting a cheaper SSD is better, and provides the same experience.
The RX 5700 XT is nearly the same as the 2070 super in performance, could save some good money that way.
Primary PC:
PSU tier list
How many watts do I need?
25 minutes ago, WikiForce said:
but nvidia recommends a 650w psu for the gpu
Despite that, a 500 watt power supply will fully handle a 6 core i7 and titan XP, so there is no reason to get a 650 watt unit.
Vendors will over recommend PSUs to cover their bases, but a 3600 is sub 100 watts and a 2070 super is about 210 watts, give or take. Nothing else in the system will consume anywhere near 300 watts, so you've got room to upgrade aplenty.
Primary PC:
PSU tier list
