Thermal Paste Help
Go to solution Solved by Kerplex,
So the push pins will put enough pressure on the cpu to spread it sufficiently?
Yes :)
When using a stock cooler or one that has mounting hardware like it (no backplate) is it safe to not spread the thermal paste?
Edit: I just put a stock dell heat sink back onto an old pentium using masscool fanner420. And I am installing a hyper TX3 on a 3570K with cooler master or masscool whichever one you guys think is better.
Edit 2: I used about a 1/4" diameter blob on the pentium, the stuff is really runny so it is not really a pea shape like everyone keeps talking about making.
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/122271-thermal-paste-help/
https://linustechtips.com/topic/122271-thermal-paste-help/#findComment-1627007
