Budget?
PSU?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221238-need-little-help/#findComment-13814303
1 minute ago, linusasfani said:
600wt psu with 6+2pin
which specific unit?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1221238-need-little-help/#findComment-13814315
and its like 100
Used 580.
Wattage wise is more than enough. But what model ( and no efficiency is not quality )
Build Log:
https://linustechtips.com/topic/1221238-need-little-help/#findComment-13814318
deepcool de600
It'll be fine as a temporary thing. But replace it when possible.
Build Log:
https://linustechtips.com/topic/1221238-need-little-help/#findComment-13814329
6 minutes ago, linusasfani said:
i dont want get any drops  in games
A 580 will be fine. A PSU has nothing to do with frame drops.
Build Log:
https://linustechtips.com/topic/1221238-need-little-help/#findComment-13814342
