Need help with wired internet.
Go to solution Solved by AMICLG,
The driver download for the killer NIC is on this page, see if this fixes anything.
I have the normal version of a MSI Z87 Mpower motherboard and my wired internet doesn't seem to work, i have tried plugging the Ethernet cable into my  laptop and it worked just fine and connected to the internet, but it doesn't seem to work on my PC, i didn't install the WiFi/Bluetooth thing that came with it because i forgot but i don't think that should affect it because i am using a wired connection instead of WiFi.  I couldn't find any wired drivers on MSI's list of drivers for the motherboard.
https://linustechtips.com/topic/122114-need-help-with-wired-internet/
