Budget (including currency):  $600<0 USD
Country: United States
Games, programs or workloads that it will be used for: world of tanks
Hello, i  am building my neighbor a PC and I was looking for suggestions on a parts list for $600 or less for a case, cpu, mobo, ram, 1tb SSD and a psu. She already owns a GTX 960 but her current pc is from 2011 and the gtx 960 doesn't work very well with it. My neighbor is not into technology so she does not have strict requirements besides budget.
What do you guys think of this first part list i came up with?
https://pcpartpicker.com/list/8Gy96R
https://linustechtips.com/topic/1220154-pc-build-for-neighbor/
Get Ryzen 3000 instead, SSD is waaaaaay overkill, PSU isn't very good.
Honestly I'd get her something used.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1220154-pc-build-for-neighbor/#findComment-13805423
1 minute ago, DominicNikon said:
What would you get used? Is there any good psus that would fit into her price point?
Check PSU tier list.
SPECS:
https://linustechtips.com/topic/1220154-pc-build-for-neighbor/#findComment-13805500
