I would have the two 120mm in the front blowing in (intake) and the 140mm in the top back blowing out (outtake)
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1217549-fan-airflow/#findComment-13782962
just about every PC fan (that I know of at least) sucks in from the "front" and blows out the "back", like this
if the 2 120mm fans are intake, you should probably have the 140mm as exhaust towards the back.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/1217549-fan-airflow/#findComment-13782968
To add to this, most fans have arrows showing the direction the air goes.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1217549-fan-airflow/#findComment-13782985
