Hello everyone,
I've got some .. weird issue.
So here how goes the story.
Everything's fine, gpu works fine, no noise, no vibrations, slight slag but nothing to worry about. I decide to, reluctantly, fix an old hdd with win7 to get back some files. I boot from my ssd with win10.
First thing, a message appear "Repairing your windows" when booting. I say allright ... we'll see if it does anything. I get my files, take off the hdd and boot again. Now it start acting weird, gpu fan (middle one) make a sort of vibration noise at high speed, the pc boot using my secondary screen, which it never did before, then switch back to the primary screen when the password is needed. Doesn't switch back though.
So I launch the Firestorm app to see how the card's doing. Play with the fans speed aaaaand for some reason, now, it makes that weird vibrating noise when it's about 70% speed.
So, I don't know if it's "normal", or if it's a known issue on this gpu, but hell the why and how it happened weirds me out.
Should I contact my seller and try to use the warranty or is there anything that I can do to fix it ?
https://linustechtips.com/topic/1215217-gpu-fan-issue/
