Budget (including currency): £720
Country: England
Games, programs or workloads that it will be used for: gaming, streaming and homework
i3-9100f cpu,
Gigabyte B365M DS3H (Socket 1151/B365 Express/DDR4/S-ATA 600/Micro ATX)
Corsair CMK16GX4M2B3200C16 Vengeance LPX 16 GB (2 x 8 GB) DDR4 3200 MHz C16 XMP 2.0 High Performance Desktop Memory Kit, Black
Seagate HDD Internal 1 TB BarraCuda SATA 3.5 Computer Hard Disk Drive - Silver
Samsung 860 EVO 500 GB SATA 2.5 Inch Internal Solid State Drive (SSD) (MZ-76E500)
Cooler Master MasterBox Q300L - mATX Mini Tower Case with Full Side Panel Display, Clean Routing, and Multiple Cooling Options
EVGA 500 W1, 80+ WHITE 500W, Power Supply 100-W1-0500-K3, Black
Gigabyte GeForce RTX 2060 OC
and then thermal paste all of these are amazon listings at the moment but all this comes up to £718.38
just wanted to ask if all these parts are compatible and i ma not bottlenecking
https://linustechtips.com/topic/1214933-first-time-building-pc-need-help/
This is a much better system. The i3 will be bottlenecking the 2060 by a bit. This graphics card is slightly worse but still great. This motherboard and psu are much more future proof too.
Country: England
i3-9100f cpu,
Look at my build, much better cpu, much better psu, also has more wattage. Good motherboard too, especially compared to any gigabyte-ds3h motherboard
I'll look into it cos the hardrive is quite small i might need 1 tb, but thanks for helping
Also hard drives are getting cheaper everyday, you can start with what any of us gave you and add more storage as needed
