Hi all so im putting together my brothers first gaming build.  Space wise we ideally dont want to go much bigger than a mid atx tower case as we dont have alot of space under his desk.
Im struggling to find a case that is not massive but will support a 240mm top mounted radiator and 3x 120mm fan support on the front.  I find best success for cooling with a pull push config (cool air in front and up through top rad as exhaust)
Any one has any suggest cases that will support what im after? looks are not  important just air flow is key.
Sorry for the vague description
https://linustechtips.com/topic/1214763-ahhhh-need-help-on-cases/
