Hi,
Ive been playing a lot of warzone lately and have become aware my CPU is going past temps ive ever seen it go before so to solve it I up'd the fan speed on my AIO cooler to 1400rpm as well as the other fans to 1200rpm and applied new thermal paste (Arctic MX4) and i've came back to 70 to 75c which is pretty daym hot. whist I fixed my GPU temp from 75 to a nice 65 while ingame it seems the Cpu goes to 75+ quite a bit. The cooler I use is a Corsair H100X I am thinking it needs to be replaced for an air cooler (Fuma 2 or D15) which isn't a problem I can do that I just want to know if doing so would improve anything.
My CPU has auto OC'd itself from 3.2 to 4.2 which happens when I enable XMP for my Ram. I am unsure if this greatly effects the temp.
(Side question would a 3.2mhz i7-8700 be good paired with a 2070 super)
Thanks in advance
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1214342-cpu-temps/
that is fine. 75 degrees is a fine temp. but if you can lower it. great
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1214342-cpu-temps/#findComment-13757681
@eeeee1 Would finding a way to go back to stock greatly decrease fps and will I still be able to use a 2070 Super with this build (When it arrives)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1214342-cpu-temps/#findComment-13757692
if you are asking a question, it depends on the game or workload.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1214342-cpu-temps/#findComment-13757697
The 8700 (especially the K version) is a known heat machine and Warzone is fairly CPU heavy.  That being said, a 3700x with a 360mm AIO I never go above 65c in Warzone.  70-75c isn't hot by any means, and you should be fine.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/1214342-cpu-temps/#findComment-13758740
@Samfisher Appreciate  it, I ended up getting a fan under my desk which will hopefully remove the hot ear away from my legs as it sucks having to sit being hot while gaming.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
https://linustechtips.com/topic/1214342-cpu-temps/#findComment-13759059
