I need some help pls
Go to solution Solved by MrBrightSyde,
Well, you got a lot to choose from, though this depends on what's in stock at the time. I'm just going to post cases and their normal prices, but due to COVID, some prices are inflated. All of them are good options, some are better than others, but it's up to you in the end to decide what case fits your needs more.
Higher-end options:
Fractal Design Meshify C, $94-99
Phanteks P400A Digital RGB, $90-99
be quiet! Pure Base 500DX, $99
Cooler Master H500, $100
CORSAIR iCUE 220T RGB Airflow, $100
Corsair 275R Airflow, $80-$90
More budget friendly options:
Phanteks P300A Mesh, $60
Phanteks P400A, $75
Cougar MX330, $50-60
Fractal Design Focus G, $65
 Budget : $100 USD
Case Form : Mid ATX Form
My head is bobbling from many cases to chose from and prices vary so much now,
Can someone please suggest me Mid ATX cases that aren't ugly to look at and also has good airflow so I won’t blow up my PC.
list a couple good ones that I can look at please thanks y’all!
https://linustechtips.com/topic/1213014-i-need-some-help-pls/
Higher-end options:
Phanteks P400A, $75
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13747501
31 minutes ago, AlmondYum said:
 Budget : $100 USD
Hey man. @MrBrightSydehit the nail on the head but I wanted to add the NZXT h510. If you can find it in stock it’s a great case that’s really easy to build in and looks fantastic for 70 bucks
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13747519
The H510 is a bit of a toaster compared to even the budget-friendly options. At $70 (and I just saw it in stock), the Cooler Master NR600 would be a better option or for $5 more, the P400A (non-Digital)
MAIN PC:
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13747539
I have it, and I wouldn’t recommend it. It is extremely hot, with my cpu hitting 70-80c while gaming.
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13747589
Higher-end options:
Phanteks P400A, $75
Thank you so much man 👏🏽
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13749259
Steve Burke is your friend.
I set the timestamp to a part of this review where you can see the CPU thermals of dozens of cases. (Please note, I chose this video because it is recent, not due to recommending the CM TD500.) A good idea to start would be to look through the cases with good CPU thermals and filter out the ones which meet your requirements in terms of size, expandability, etc..
https://linustechtips.com/topic/1213014-i-need-some-help-pls/#findComment-13749474
