7950 gx2 help
Go to solution Solved by kelvinhall05,
Still decent cards. About the performance of a modern-low end card but with higher power consumption and they run hotter. Either keep them as backups or sell them for like $50 each.
They're basically equivalent to 1050 Tis in performance. You could put them in a ~$500 system and have better performance than integrated graphics, even better than the 3400G's performance. Putting them in a crappy optiplex would allow you to play games with them, or if a system doesn't have integrated graphics use it as a way to get video.
https://linustechtips.com/topic/1212211-7950-gx2-help/#findComment-13741148
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1212211-7950-gx2-help/#findComment-13741172
God damn, the GeForce 7950 GX2 hasn't been relevant for a while. I'm sure you could use it in a Windows XP build, but I'm sure there's a market for it.
https://linustechtips.com/topic/1212211-7950-gx2-help/#findComment-13741184
