I've thought about that but never went into doing it myself.  Pau's hardware did it and he used I think long standoffs and inserted them into the wood to mount his motherboard.  You could also use some wood insert and screw the standoffs in the insert.  Not sure if it works well tho.
https://www.amazon.ca/s?k=wood+insert&ref=nb_sb_noss_2
Paul's video...
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1211615-help/#findComment-13736850
