Hey guys, so recently ive been getting frame spikes in game. I then ran cinebench and heaven and a few other stress testers and my scores were perfectly fine, so that eliminates the gpu and cpu as the problem. The only other thing I could see casuing this is my ram. Which ive been told wont cause spikes in game but I dont really know. Anybody know anything?
2060 super
ryzen 7 3700x
aorus elite x570
sseaonic gx-650
g skill trident z neo 2x8 3600
https://linustechtips.com/topic/1211017-games-not-running-well/
Is this only recently and it was working fine before? If so, you need to work out what has changed from before if you've eliminated cpu & gpu. Do a mem test to see if the RAM is faulty but I find that unlikely if everything else is running fine. Have you updated GPU drivers? If so, try rolling back to an earlier one and see if it happens still.
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13732088
What is a good mem test program?
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13733875
memtest86 or memtest86+ are always recommended, and I think some BIOS have it built in, or Linux distros in the grub (unRAID). But I also had this issue a few years back, CPU and GPU died together. And I'm still running the RAM in my current system, which used to not overclock with XMP but does now. It's a haunting issue. I also just commented on another thread just started not too long ago with the same issue.
Primary System: Bassenji-9900K OS: Windows 10 Pro CPU: i9-9900K w/cooler Noctua NH-D15 RAM: Corsair Dominator Platinum 2400Mhz 16GB/4 MOBO: Gigabyte Aorus Gaming WiFi PSU: Seasonic Prime 1000W GPU: Gigabyte Aorus GTX 1080Ti Storage: Samsung 960 Pro M.2 256GB, x2 Raid0 Samsung 840 Pro 512GB, Seagate SSHD 1TB Monitor: ASUS PG278q 1440p144hz
Secondary System: Bassenji-6700K OS: Windows 10 Pro CPU: i7-6700K w/cooler Cooler Master Hyper 212 EVO RAM: G.Skill Ripjaws V 8GB/2 MOBO: ASUS Maximus VIII Hero Alpha PSU: Corsair HX850 GPU: Gigabyte Aorus GTX 1050Ti Storage: Silicon Power Ace A55 128GB, x2 Raid0 WD Black 1TB Monitor: ASUS PB278q 1440p60hz
NAS: DataBass OS: FreeNAS CPU: i7-3770K RAM: G.Skill Trident X 16GB/4 MOBO: ASUS P8Z77-V Deluxe PSU: forgot 750W Storage: x4 RaidZ WD Red 2TB w/128GB SSD L2ARC, x3 Raid1 WD Green 2TB w/128GB SSD L2ARC, x2 Raid1 WD Purple 4TB
Hypervisor: Ryxen OS: XCP-NG CPU: Ryzen 2700 RAM: forgot 32GB/4 MOBO: ASUS Prime X370-Pro PSU: Corsair CM450 Storage: Samsung 840 Evo 128GB
Router/Firewall: Teion OS: pfSense CPU: i5-6500T RAM: G.Skill Ripjaws V 8GB/2 MOBO: ASUS H170m-Plus PSU: forgot 250W Storage: x2 Raid1 forgot 16GB SSD
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13734688
Cool, Ill try that.
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13734720
Did you ever figure out the issue?
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13734733
Sadly, no. My CPU and GPU both died at the same time, so I had to use my second system for a few months 'till they were replaced. After rebuilding, it was so long I kinda forgot and was just relieved to not deal with it anymore. My best guess is power issues, but my SSD where my OS was, was also failing later on so it could've been that. But @bryce backer said they've tried swapping drives too, and I still use the same PSU and mobo together as my second system. I don't game on it but use it for recording and don't have any framerate issues.
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13734756
I currently just got a new psu and am using a ups.
https://linustechtips.com/topic/1211017-games-not-running-well/#findComment-13734765
