Depends on how you want them to connect. Need to be specific.
There are telescopic fittings as well as rotary fittings that can do it.
Just side by side. I think two connections, one on the top and one on the bottom for flow between them. The out port on the right to go to the pump, and the in port on the left side to come from the GPU or Rad.
You can use a male to male rotary fitting if you have the two ports directly facing each other, but if you want it angled like they are in the photo a set of angled adapters would be necessary in conjunction with the male to male fitting.
Barrow G1/4" Male to Male D-Plug Fitting, 25mm, White - Newegg.com
